Where are the 0.1 mm comming from ?
First layer pression ?
For a second test, I use a first layer at 0.21 and the result is near the same...
That does not play a role -- Whatever your first layer is, the height is equalized after a couple of layers.darkdvd wrote: First layer pression ?
