Let's get a conversation rolling.... what have you printed lately...or working on?
Me... upgrades!
What are you printing lately?
- Country_Bubba
Re: What are you printing lately?
my most recent projects have been cases to house pi zero w's and pi cameras. Have three of them now.
I've printed a few Pi3b cases that have a cover that supports a cooling fan...and can bolt onto 2020 rails
cam clip 3.0
I found this great little bag clip and have been printing several for every member of the family.
I've been printing various things for work.
I have a very interesting project that I 3D printed as a sort of prototype to see how it all fitted together.
When I get permission I'll post some photos of it.
Did this
The other end of the scale, size wise.
These small gears are for a project I am working on.
dbhosttexas
Raspberry Pi 5 / Pimoroni base cases.
Ryobi BT3x00 sliding miter fence ends
Ethernet cable organizers
Eero pro 6 wall mounts.
Tie Fighter Echo Dot V3 desktop stands
In design phase of camper van wall mount electrical control panel. I.E. wall mounted box that will house 12V power sockets, USB charging ports, water pump control switch, gray and fresh water level sensors / switch, Thermostat and controls for AC and heat. Control / data panel for inverter.
In design phase of... Updated bottom half of Raspberry Pi 5 / Pimoroni base cases, Simply adding mounting tabs to permit me to wall mount the Pi in the camper van. Simply taking the STL file and adding an ear with a hole through it for the screws on each corner, Probably bevel the hole for flat screws.
Because of the high UV exposure / automotive nature of the 2 in progress designs, I am trying to learn to print with PETG, and that stuff is a bit, fussier than PLA... I'll get there, I hope.
