Z-axix linear bearings
- antiklesys
Re: Z-axix linear bearings
@Neotko : did you have a chance to upload the Z bed stabilizer files for the UMO+ yet ?
Oh no sorry! Much testing this weekend. Will try tomorrow!!
Finally had some time to replace the bearings. This is a short video of how bad the stock bearings were
With the new bearings...it's a totally different printer. Not a single glitch on the prints...and the buildplate lowers itself when the print is done
Yikes, that's bad
Looks like the surgery to replace went well?
Yes, I will post some pictures in my printer thread.
But I have to do it from my Mac due to the image-rotate issue with the forum software
....which only you seem to have, for the record
Using the most popular smartphone...
If it is as you say that thumbnails are wrong, but not the original, then it is truly an issue with the forum software...because that thumbnail is generated by the forum
My iPhone uploads images with no issue, the latest pics I uploaded were on from there. Be sure that the thumbnail you see on the iPhone camera roll is aligned right too.
Test
test 2
test 2
Yes, the vertical is where I have seen issues...where the thumbnail is wrong but the pic displays fine once clicked.
Use the square format and it gets even worse.
mutley
- 3D Printer(s): UM2 UMO MendelFlex DeltaFlex
Been having problems with my UMO and UM2 intermitent banding. Lots of investigating, often putting it down to the cross rod gantry bearings. Changed them with cheap chinese bearings, no difference.
More recently a blown UM2 heatbed, and known ever so slightly notchy bearing on UMO Z axis, prompted me to go for some quality LM12's. They arrived today, fitting in next day or so. They came in a box, wax proof paper, id forgotten what a quality bearing package looked like. Very much looking forward to getting these babies fitted, and hopefully saying hello to aligned layers again.
But having gone for new bearings, and doing some searching, I was surpsied to see how many Z axis bearing issues do occur on these machines. Thinking logically about it though, it is not that surprising.
Will update once fitted.
That's disappointing to find out that what's in your expensive printer isn't always high quality parts.
Yes, in a cheap Chinese clone...fine. But not I am original Ultimaker.
But I have to give good credit to 3D-Verkstan for how they handled this
mutley
Just a quick update on my use of the Japanese LM12 bearings for the Z axis.
Disassembled machine as required to complete the installation, cleaned and lubed the 12mm rods, carefully dropped the new bearings on, they felt a little tight, and almost notchy, but as per usual with a good fitting LM bearing, a bit of back and forth movement soon had them feeling a lot smoother (but still ever so slightly notchy, didnt feel like "ball raced" if you understand me).
Re-assembled and completed a few test prints. All good, no banding evident. Pleased the effort (and expense) paid off.
