My primary usage is milling carbon plates, but I have some projects with aluminum which is more demanding. I am interested in PCB milling, but I never tried that.martin-bienz wrote:Cool Amedee, looks great! I especially like the proximity endstops. Looks extremly sturdy... PCB milling? Alu, wood?
I am also using POM which is very easy to machine.
The proximity end-stops are actually quite cheap and very reliable; these are NC as well (actually mine are 'Home sensors', not really end-stops but that does not matter).martin-bienz wrote: As you know, I just built an MPCNC and yesterday I mounted all endstops (coincidence?) but just "normal" switch-endstops in NC configuration. I use RAMPS and Marlin to control the CNC, makes it easy as I know marlin allready a bit.
For the electronics, I spent a lot of time on that. At some point in time I decided I wanted to to be able to generate steps faster than 100KHz, and that eliminates quite a lot of possibilities, including the Arduino based solutions...
I am using more and more F360 for 3D printing stuff, so it makes sense to me to concentrate on that for the CAD, and since it has integrated CAM it is the logical next step.martin-bienz wrote: Also here, at the same point. I am not sure if I want to start with F360 as a CNC application (as it's rather complex to setup and then the post-processor, luckily there is one for marlin...). I am currently looking at Estlcam (http://www.estlcam.com/), it's pretty cost effective I would say, but I have not yet tried it.
Most alternatives would require a Windows environment that I don't have.
I am a Linux (/Max) guy, so F360 on Mac / LinuxCNC for the router make sense to me -- we will see after I build some experience around these tools.
