Re: UMO / UMO+ Firmware
Posted: December 16th, 2016, 6:04 pm
You builders rocks. Btw can someone save that hash yo 'save' the settings?
A place for people to learn 3D Printing!
http://mail.3dprintingforum.us/
It has always been there -- here is the story behind the hash:Neotko wrote:Btw can someone save that hash yo 'save' the settings?
Code: Select all
#include <avr/pgmspace.h>
#include "Configuration.h"
#ifdef ENABLE_ULTILCD2
#include "Marlin.h"
#include "cardreader.h"//This code uses the card.longFilename as buffer to store data, to save memory.
#include "temperature.h"
#include "ConfigurationStore.h"
#include "UltiLCD2.h"
#include "UltiLCD2_hi_lib.h"
#include "UltiLCD2_menu_material.h"
#include "UltiLCD2_menu_first_run.h"
#include "UltiLCD2_menu_print.h"
#define BED_CENTER_ADJUST_X (X_MAX_POS/2)
#define BED_CENTER_ADJUST_Y ((int)Y_MAX_LENGTH - 10)
#define BED_LEFT_ADJUST_X 10
#define BED_LEFT_ADJUST_Y 20
#define BED_RIGHT_ADJUST_X (X_MAX_POS - 10)
#define BED_RIGHT_ADJUST_Y 20
static void lcd_menu_first_run_init_2();
static void lcd_menu_first_run_init_3();
static void lcd_menu_first_run_bed_level_center_adjust();
static void lcd_menu_first_run_bed_level_left_adjust();
static void lcd_menu_first_run_bed_level_right_adjust();
static void lcd_menu_first_run_bed_level_paper();
static void lcd_menu_first_run_bed_level_paper_center();
static void lcd_menu_first_run_bed_level_paper_left();
static void lcd_menu_first_run_bed_level_paper_right();
static void lcd_menu_first_run_material_load();
static void lcd_menu_first_run_material_select_1();
static void lcd_menu_first_run_material_select_material();
static void lcd_menu_first_run_material_select_confirm_material();
static void lcd_menu_first_run_material_select_2();
static void lcd_menu_first_run_material_load_heatup();
static void lcd_menu_first_run_material_load_insert();
static void lcd_menu_first_run_material_load_forward();
static void lcd_menu_first_run_material_load_wait();
static void lcd_menu_first_run_print_1();
static void lcd_menu_first_run_print_card_detect();
#define DRAW_PROGRESS_NR_IF_NOT_DONE(nr) do { if (!IS_FIRST_RUN_DONE()) { lcd_lib_draw_stringP((nr < 10) ? 100 : 94, 0, PSTR( #nr "/21")); } } while(0)
#define DRAW_PROGRESS_NR(nr) do { lcd_lib_draw_stringP((nr < 10) ? 100 : 94, 0, PSTR( #nr "/21")); } while(0)
#define CLEAR_PROGRESS_NR(nr) do { lcd_lib_clear_stringP((nr < 10) ? 100 : 94, 0, PSTR( #nr "/21")); } while(0)
//Run the first time you start-up the machine or after a factory reset.
void lcd_menu_first_run_init()
SELECT_MAIN_MENU_ITEM(0);
lcd_info_screen(lcd_menu_first_run_init_2, NULL, PSTR("CONTINUE"));
DRAW_PROGRESS_NR_IF_NOT_DONE(1);
lcd_lib_draw_string_centerP(10, PSTR("Welcome to the first"));
lcd_lib_draw_string_centerP(20, PSTR("startup of your"));
lcd_lib_draw_string_centerP(30, PSTR("Ultimaker! Press the"));
lcd_lib_draw_string_centerP(40, PSTR("button to continue"));
lcd_lib_update_screen();
static void homeAndParkHeadForCenterAdjustment2()
add_homeing[Z_AXIS] = 0;
enquecommand_P(PSTR("G28 Z0 X0 Y0"));
char buffer[32];
sprintf_P(buffer, PSTR("G1 F%i Z%i X%i Y%i"), int(homing_feedrate[0]), 35, X_MAX_LENGTH/2, BED_CENTER_ADJUST_Y);
enquecommand(buffer);
//Started bed leveling from the calibration menu
void lcd_menu_first_run_start_bed_leveling()
lcd_question_screen(lcd_menu_first_run_bed_level_center_adjust, homeAndParkHeadForCenterAdjustment2, PSTR("CONTINUE"), lcd_menu_main, NULL, PSTR("CANCEL"));
lcd_lib_draw_string_centerP(10, PSTR("I will guide you"));
lcd_lib_draw_string_centerP(20, PSTR("through the process"));
lcd_lib_draw_string_centerP(30, PSTR("of adjusting your"));
lcd_lib_draw_string_centerP(40, PSTR("buildplate."));
static void homeAndRaiseBed()
enquecommand_P(PSTR("G28 Z0"));
char buffer[32];
sprintf_P(buffer, PSTR("G1 F%i Z%i"), int(homing_feedrate[0]), 35);
lcd_info_screen(lcd_menu_first_run_init_3, homeAndRaiseBed, PSTR("CONTINUE"));
DRAW_PROGRESS_NR_IF_NOT_DONE(2);
lcd_lib_draw_string_centerP(10, PSTR("Because this is the"));
lcd_lib_draw_string_centerP(20, PSTR("first startup I will"));
lcd_lib_draw_string_centerP(30, PSTR("walk you through"));
lcd_lib_draw_string_centerP(40, PSTR("a first run wizard."));
static void homeAndParkHeadForCenterAdjustment()
enquecommand_P(PSTR("G28 X0 Y0"));
char buffer[32];
sprintf_P(buffer, PSTR("G1 F%i Z%i X%i Y%i"), int(homing_feedrate[0]), 35, BED_CENTER_ADJUST_X, BED_CENTER_ADJUST_Y);
lcd_info_screen(lcd_menu_first_run_bed_level_center_adjust, homeAndParkHeadForCenterAdjustment, PSTR("CONTINUE"));
DRAW_PROGRESS_NR_IF_NOT_DONE(3);
lcd_lib_draw_string_centerP(10, PSTR("After transportation"));
lcd_lib_draw_string_centerP(20, PSTR("we need to do some"));
lcd_lib_draw_string_centerP(30, PSTR("adjustments, we are"));
lcd_lib_draw_string_centerP(40, PSTR("going to do that now."));
static void parkHeadForLeftAdjustment()
add_homeing[Z_AXIS] -= current_position[Z_AXIS];
current_position[Z_AXIS] = 0;
plan_set_position(current_position[X_AXIS], current_position[Y_AXIS], current_position[Z_AXIS], current_position[E_AXIS]);
char buffer[32];
sprintf_P(buffer, PSTR("G1 F%i Z5"), int(homing_feedrate[Z_AXIS]));
sprintf_P(buffer, PSTR("G1 F%i X%i Y%i"), int(homing_feedrate[X_AXIS]), BED_LEFT_ADJUST_X, BED_LEFT_ADJUST_Y);
sprintf_P(buffer, PSTR("G1 F%i Z0"), int(homing_feedrate[Z_AXIS]));
LED_GLOW();
if (lcd_lib_encoder_pos == ENCODER_NO_SELECTION)
lcd_lib_encoder_pos = 0;
if (printing_state == PRINT_STATE_NORMAL && lcd_lib_encoder_pos != 0 && movesplanned() < 4)
current_position[Z_AXIS] -= float(lcd_lib_encoder_pos) * 0.05;
plan_buffer_line(current_position[X_AXIS], current_position[Y_AXIS], current_position[Z_AXIS], current_position[E_AXIS], 60, 0);
if (movesplanned() > 0)
lcd_info_screen(NULL, NULL, PSTR("CONTINUE"));
else
lcd_info_screen(lcd_menu_first_run_bed_level_left_adjust, parkHeadForLeftAdjustment, PSTR("CONTINUE"));
DRAW_PROGRESS_NR_IF_NOT_DONE(4);
lcd_lib_draw_string_centerP(10, PSTR("Rotate the button"));
lcd_lib_draw_string_centerP(20, PSTR("until the nozzle is"));
lcd_lib_draw_string_centerP(30, PSTR("a millimeter away"));
lcd_lib_draw_string_centerP(40, PSTR("from the buildplate."));
static void parkHeadForRightAdjustment()
char buffer[32];
sprintf_P(buffer, PSTR("G1 F%i X%i Y%i"), int(homing_feedrate[X_AXIS]), BED_RIGHT_ADJUST_X, BED_RIGHT_ADJUST_Y);
LED_GLOW();
lcd_info_screen(lcd_menu_first_run_bed_level_right_adjust, parkHeadForRightAdjustment, PSTR("CONTINUE"));
DRAW_PROGRESS_NR_IF_NOT_DONE(5);
lcd_lib_draw_string_centerP(10, PSTR("Turn left buildplate"));
lcd_lib_draw_string_centerP(20, PSTR("screw till the nozzle"));
lcd_lib_draw_string_centerP(30, PSTR("is a millimeter away"));
LED_GLOW();
lcd_info_screen(lcd_menu_first_run_bed_level_paper, NULL, PSTR("CONTINUE"));
DRAW_PROGRESS_NR_IF_NOT_DONE(6);
lcd_lib_draw_string_centerP(10, PSTR("Turn right buildplate"));
static void parkHeadForCenterAdjustment()
char buffer[32];
sprintf_P(buffer, PSTR("G1 F%i X%i Y%i"), int(homing_feedrate[X_AXIS]), X_MAX_LENGTH / 2, BED_CENTER_ADJUST_Y);
lcd_info_screen(lcd_menu_first_run_bed_level_paper_center, parkHeadForCenterAdjustment, PSTR("CONTINUE"));
DRAW_PROGRESS_NR_IF_NOT_DONE(7);
lcd_lib_draw_string_centerP(10, PSTR("Repeat this step, but"));
lcd_lib_draw_string_centerP(20, PSTR("now use a sheet of"));
lcd_lib_draw_string_centerP(30, PSTR("paper to fine-tune"));
lcd_lib_draw_string_centerP(40, PSTR("the buildplate level."));
LED_GLOW();
else
lcd_info_screen(lcd_menu_first_run_bed_level_paper_left, parkHeadForLeftAdjustment, PSTR("CONTINUE"));
DRAW_PROGRESS_NR_IF_NOT_DONE(8);
lcd_lib_draw_string_centerP(10, PSTR("Slide a paper between"));
lcd_lib_draw_string_centerP(20, PSTR("buildplate and nozzle"));
lcd_lib_draw_string_centerP(30, PSTR("until you feel a"));
lcd_lib_draw_string_centerP(40, PSTR("bit resistance."));
LED_GLOW();
lcd_info_screen(lcd_menu_first_run_bed_level_paper_right, parkHeadForRightAdjustment, PSTR("CONTINUE"));
DRAW_PROGRESS_NR_IF_NOT_DONE(9);
lcd_lib_draw_string_centerP(20, PSTR("Repeat this for"));
lcd_lib_draw_string_centerP(30, PSTR("the left corner..."));
static void homeBed()
add_homeing[Z_AXIS] += LEVELING_OFFSET; //Adjust the Z homing position to account for the thickness of the paper.
// now that we are finished, save the settings to EEPROM
Config_StoreSettings();
LED_GLOW();
if (IS_FIRST_RUN_DONE())
lcd_info_screen(lcd_menu_main, homeBed, PSTR("DONE"));
else
lcd_info_screen(lcd_menu_first_run_material_load, homeBed, PSTR("CONTINUE"));
DRAW_PROGRESS_NR_IF_NOT_DONE(10);
lcd_lib_draw_string_centerP(30, PSTR("the right corner..."));
static void parkHeadForHeating()
lcd_material_reset_defaults();
enquecommand_P(PSTR("G1 F12000 X110 Y10"));
enquecommand_P(PSTR("M84"));//Disable motor power.
lcd_info_screen(lcd_menu_first_run_material_select_1, parkHeadForHeating, PSTR("CONTINUE"));
DRAW_PROGRESS_NR(11);
lcd_lib_draw_string_centerP(10, PSTR("Now that we leveled"));
lcd_lib_draw_string_centerP(20, PSTR("the buildplate"));
lcd_lib_draw_string_centerP(30, PSTR("the next step is"));
lcd_lib_draw_string_centerP(40, PSTR("to insert material."));
if (eeprom_read_byte(EEPROM_MATERIAL_COUNT_OFFSET()) == 1)
digipot_current(2, motor_current_setting[2]);//Set E motor power to default.
for(uint8_t e=0; e<EXTRUDERS; e++)
lcd_material_set_material(0, e);
SET_FIRST_RUN_DONE();
currentMenu = lcd_menu_first_run_material_load_heatup;
return;
lcd_info_screen(lcd_menu_first_run_material_select_material, doCooldown, PSTR("READY"));
DRAW_PROGRESS_NR(12);
lcd_lib_draw_string_centerP(10, PSTR("Next, select the"));
lcd_lib_draw_string_centerP(20, PSTR("material you will"));
lcd_lib_draw_string_centerP(30, PSTR("insert in this"));
lcd_lib_draw_string_centerP(40, PSTR("Ultimaker2."));
static char* lcd_material_select_callback(uint8_t nr)
eeprom_read_block(card.longFilename, EEPROM_MATERIAL_NAME_OFFSET(nr), 8);
return card.longFilename;
static void lcd_material_select_details_callback(uint8_t nr)
lcd_lib_draw_stringP(5, 53, PSTR("Select the material"));
LED_GLOW();
uint8_t count = eeprom_read_byte(EEPROM_MATERIAL_COUNT_OFFSET());
lcd_scroll_menu(PSTR("MATERIAL"), count, lcd_material_select_callback, lcd_material_select_details_callback);
CLEAR_PROGRESS_NR(13);
if (lcd_lib_button_pressed)
lcd_material_set_material(SELECTED_SCROLL_MENU_ITEM(), e);
lcd_change_to_menu(lcd_menu_first_run_material_select_confirm_material);
strcat_P(card.longFilename, PSTR(" as material,"));
LED_GLOW();
lcd_question_screen(lcd_menu_first_run_material_select_2, NULL, PSTR("YES"), lcd_menu_first_run_material_select_material, NULL, PSTR("NO"));
DRAW_PROGRESS_NR(14);
lcd_lib_draw_string_centerP(20, PSTR("You have chosen"));
lcd_lib_draw_string_center(30, card.longFilename);
lcd_lib_draw_string_centerP(40, PSTR("is this right?"));
lcd_info_screen(lcd_menu_first_run_material_load_heatup, NULL, PSTR("CONTINUE"));
DRAW_PROGRESS_NR(15);
lcd_lib_draw_string_centerP(10, PSTR("Now your Ultimaker2"));
lcd_lib_draw_string_centerP(20, PSTR("knows what kind"));
lcd_lib_draw_string_centerP(30, PSTR("of material"));
lcd_lib_draw_string_centerP(40, PSTR("it is using."));
setTargetHotend(material[0].temperature, 0);
int16_t temp = degHotend(0) - 20;
int16_t target = degTargetHotend(0) - 10 - 20;
if (temp < 0) temp = 0;
if (temp > target)
volume_to_filament_length[e] = 1.0;//Set the extrusion to 1mm per given value, so we can move the filament a set distance.
currentMenu = lcd_menu_first_run_material_load_insert;
temp = target;
uint8_t progress = uint8_t(temp * 125 / target);
if (progress < minProgress)
progress = minProgress;
else
minProgress = progress;
lcd_basic_screen();
DRAW_PROGRESS_NR(16);
lcd_lib_draw_string_centerP(10, PSTR("Please wait,"));
lcd_lib_draw_string_centerP(20, PSTR("printhead heating for"));
lcd_lib_draw_string_centerP(30, PSTR("material loading"));
lcd_progressbar(progress);
static void runMaterialForward()
//Override the max feedrate and acceleration values to get a better insert speed and speedup/slowdown
float old_max_feedrate_e = max_feedrate[E_AXIS];
float old_retract_acceleration = retract_acceleration;
max_feedrate[E_AXIS] = FILAMENT_INSERT_FAST_SPEED;
retract_acceleration = FILAMENT_LONG_MOVE_ACCELERATION;
current_position[E_AXIS] = 0;
plan_set_e_position(current_position[E_AXIS]);
current_position[E_AXIS] = FILAMENT_FORWARD_LENGTH;
plan_buffer_line(current_position[X_AXIS], current_position[Y_AXIS], current_position[Z_AXIS], current_position[E_AXIS], FILAMENT_INSERT_FAST_SPEED, 0);
//Put back origonal values.
max_feedrate[E_AXIS] = old_max_feedrate_e;
retract_acceleration = old_retract_acceleration;
LED_GLOW();
if (movesplanned() < 2)
current_position[E_AXIS] += 0.5;
plan_buffer_line(current_position[X_AXIS], current_position[Y_AXIS], current_position[Z_AXIS], current_position[E_AXIS], FILAMENT_INSERT_SPEED, 0);
lcd_info_screen(lcd_menu_first_run_material_load_forward, runMaterialForward, PSTR("CONTINUE"));
DRAW_PROGRESS_NR(17);
lcd_lib_draw_string_centerP(10, PSTR("Insert new material"));
lcd_lib_draw_string_centerP(20, PSTR("from the rear of"));
lcd_lib_draw_string_centerP(30, PSTR("your Ultimaker2,"));
lcd_lib_draw_string_centerP(40, PSTR("above the arrow."));
lcd_basic_screen();
DRAW_PROGRESS_NR(18);
lcd_lib_draw_string_centerP(20, PSTR("Loading material..."));
if (!blocks_queued())
lcd_lib_beep();
led_glow_dir = led_glow = 0;
digipot_current(2, motor_current_setting[2]*2/3);//Set E motor power lower so the motor will skip instead of grind.
currentMenu = lcd_menu_first_run_material_load_wait;
long pos = st_get_position(E_AXIS);
long targetPos = lround(FILAMENT_FORWARD_LENGTH*axis_steps_per_unit[E_AXIS]);
uint8_t progress = (pos * 125 / targetPos);
LED_GLOW();
lcd_info_screen(lcd_menu_first_run_print_1, doCooldown, PSTR("CONTINUE"));
DRAW_PROGRESS_NR(19);
lcd_lib_draw_string_centerP(10, PSTR("Push button when"));
lcd_lib_draw_string_centerP(20, PSTR("material exits"));
lcd_lib_draw_string_centerP(30, PSTR("from nozzle..."));
plan_buffer_line(current_position[X_AXIS], current_position[Y_AXIS], current_position[Z_AXIS], current_position[E_AXIS], FILAMENT_INSERT_EXTRUDE_SPEED, 0);
lcd_info_screen(lcd_menu_first_run_print_card_detect, NULL, PSTR("ARE YOU READY?"));
DRAW_PROGRESS_NR(20);
lcd_lib_draw_string_centerP(20, PSTR("I'm ready let's"));
lcd_lib_draw_string_centerP(30, PSTR("make a 3D Print!"));
if (!card.sdInserted)
lcd_info_screen(lcd_menu_main);
DRAW_PROGRESS_NR(21);
lcd_lib_draw_string_centerP(20, PSTR("Please insert SD-card"));
lcd_lib_draw_string_centerP(30, PSTR("that came with"));
lcd_lib_draw_string_centerP(40, PSTR("your Ultimaker2..."));
card.release();
return;
if (!card.isOk())
lcd_lib_draw_string_centerP(30, PSTR("Reading card..."));
card.initsd();
return;
lcd_info_screen(lcd_menu_print_select, NULL, PSTR("LET'S PRINT"));
lcd_lib_draw_string_centerP(10, PSTR("Select a print file"));
lcd_lib_draw_string_centerP(20, PSTR("on the SD-card"));
lcd_lib_draw_string_centerP(30, PSTR("and press the button"));
lcd_lib_draw_string_centerP(40, PSTR("to print it!"));
#endif//ENABLE_ULTILCD2
Maybe this helps?antiklesys wrote:Started working on it, cutting out all the unnecessary "crap" for now.
Will keep you posted
Code: Select all
char buffer[32];
char buffer[32];
parkHeadForCenterAdjustment();
char buffer[32];
parkHeadForRightAdjustment();
//still need to fix this one
parkHeadForLeftAdjustment();
char buffer[32];
parkHeadForLeftAdjustment(); //temporary for testing only
//lcd_menu_first_run_bed_level_center_adjust();
char buffer[32];
homeAndParkHeadForCenterAdjustment2();
static void bed_leveling2()
char buffer[32];
homeAndParkHeadForCenterAdjustment();
