Page 3 of 4
Posted: January 30th, 2017, 8:34 am
You did launch the full print? I would have cut a piece to check supports first ummm
Hopefully the 2 layers of roft supports should come out without too much trouble.
Posted: January 30th, 2017, 9:02 am
Yes, as I said, I was going to give it a go!
That one close up is the only spot that looks a little odd but should clean up with a knife. I am at work now so I'll know more when I get home
Posted: January 30th, 2017, 5:38 pm
Results
On the Pro side, the bottom supports came off in segments, much easier than Cura
On the bad side, the ends on the part contain two holes and a slot. On each side of this part, it's blocked up and I'm not sure I can remove what's there. One hole wasn't made...just a dimple. :(
The bottom two prong pieces also have no holes. Just an indentation where one is
The external finish is really nice tho!
I have a new one printing with Cura now.
Posted: January 30th, 2017, 5:42 pm
Oh that part has holes too. With the cross section viewer it could be really easy to remove the supports on that cavities. That's why I was surprised you clickprint it. I'm not familiar with the object and it's needs. I focused on the very small area that prints over supports, that a very hard thing to print on any printer (except um3 when th pva).
Posted: January 30th, 2017, 5:47 pm
Posted: January 30th, 2017, 5:49 pm
Others are printing it up. It's a challenge to orient and of course the long print times
Posted: January 30th, 2017, 5:51 pm
I appreciate your effort!
(It won't fit an Ultimaker 3)
Posted: January 30th, 2017, 5:58 pm
I think it can be very very easy redesign to cut it in two using the same clamp system and would print with minimal to none supports.
Posted: January 30th, 2017, 6:00 pm
Let's try it
I'm out of filament (nGen) after this print but I have lots of ColorFabb PLA. I also noticed Frederick had some unique fan layer cooling set up in that
Posted: January 30th, 2017, 6:08 pm
Do you have access to the original file in step or something editable?
Posted: January 30th, 2017, 7:03 pm
I do. I'll attach it in a few minutes
Posted: January 30th, 2017, 7:21 pm
Here it is
Cary Sphere_R6.STL
(11.76 MiB) Downloaded 834 times
Posted: January 31st, 2017, 8:48 am
Here is last night's print and what I get 25% of the time with Cura. One piece not fully supported gets separated. I wish Cura offered supports you can edit and fine tune. Adding a z height support (roof) makes for a very difficult supper to removed. What's most frustrating is 75% of the time the print comes out great. Then....one like this
Posted: February 1st, 2017, 9:14 am
Looking forward to seeing what the next factory file looks like
Posted: March 24th, 2017, 5:53 pm
I guess Neo lost interest? :)
