On the UM3?
LePaul wrote:On the UM3?
Yeah
Thanks men. Without you this um3 would be just a very expensive lightbox XDgudo wrote:Hi to all !
@ Neotko
Sweet !
My plan is to refurbish completely the machine, so I don't think it will print anything before next yearLePaul wrote:I'm curious how it performs...same? Better? Worse? than the stock?
But the idea is to use it mainly for materials that the UMO hot end can't print because of the temperature...
What? Bugs in s3d? :O (sorry, couldn't help myself)Neotko wrote: Fonts quality should be better but S3D has a small bug that doesn't allow me to wipe+retract when using dual.
Other than that, i've been gorging myself upon the unholy candy called "Pepernoten" because of sinterklaas (and the reception has a big jar filled with them, which I pass every time I get up to get coffee...)
Indeed is a bit annoying bug (yeah XD). Basically is a bit stupid and while activating wipe+retract it confuses and 1/5 times uses the retraction distance + toolchange distance. Ofc my feeder can keep up with that but is changes the wipe making visible errors on some spots. So yeah, Cura is MUCH better atm for dual. But disabling that wipe+retract fixes the issue and changing the temps/speed/coasting I can get almost (just almost) close to the same print results.nallath wrote:What? Bugs in s3d? :O (sorry, couldn't help myself)Neotko wrote: Fonts quality should be better but S3D has a small bug that doesn't allow me to wipe+retract when using dual.
Oh forgot to add. The bug occurs while doing one yo other process. In theory it should only happen prior a tool change, but nope. Anyhow I think I got a script to solve the issue. Not sure yet
- ivan.akapulko
@Amedee! Happy birthday, dude!
Happy birthday to Amedee, your catching up with us oldies
- martin-bienz
Happy birthday Amedee! Santa coming to Belgium?
Happy birthday @amedee !!!!!
Grattis på födelsedagen @amedee !
Thanks guys, but it is actually not my birthday
, but the one of the bear
Happy Bearthday then!!
Best video ever.
