New 3D Printer build
Posted: August 2nd, 2016, 9:20 pm
by KevinA
Just finished building a HICTOP 3DP11 and decided it needed a wiring harness instead of the one length fits all vendor decision. I can find all the pins and bodies for the Dupont servo style connectors but the XH2.54 JST style connectors are a problem. Does anyone have the part number for the pins of the XH2.54 or JST style connectors?
Thanks
Re: New 3D Printer build
Posted: August 2nd, 2016, 11:52 pm
Moved this to the HICTOP RepRap Prusa I3 area for you
Posted: August 15th, 2016, 11:20 am
by Chip Luck
KevinA wrote:Just finished building a HICTOP 3DP11 and decided it needed a wiring harness instead of the one length fits all vendor decision. I can find all the pins and bodies for the Dupont servo style connectors but the XH2.54 JST style connectors are a problem. Does anyone have the part number for the pins of the XH2.54 or JST style connectors?
Thanks
Not off hand, you might want to search on the internet or post to the official RepRap forums over there, they have a large crowd...
http://forums.reprap.org/list.php?406
Posted: August 26th, 2016, 12:38 pm
by KevinA
The XH terminals are called XH2.54mm Female Pin Connector Terminal but after you find them they add they are for DUPONT connectors, they aren't, see images.
XH connector part numbers chart to search images and a Dupont Kit I found...
I have a Molex tool (63819-0000 ) that I modified to use to crimp the these connectors.
