How do you add Helper discs?
I have a large print and it was suggested to add helper discs to the corner
But they didn't state how that is done!
Re: How do you add Helper discs?
Post by nilrog »
If it's for S3D @neotko has a nice tutorial on Youmagine, and probably here also.
Is that the one we're he puts a thin washer by the corners to increase the brim area?
Post by nilrog »
Yes, that's the one. Haven't tried it yet but I will soon.
Post by nilrog »
Yea and Peggyb wrote how to do it on Cura.
All the info here
https://ultimaker.com/en/community/3931 ... it-on-cura
I even included the fff as sample to see it.
Also s3d allows to export the stl so you can save the washer that works for you.
I messed around with this....it appears you can just move a pre-made disc (found several on Thingiverse) and move them onto the edges of the print?
My concern was it would raise the printed object up instead of merging into the print itself
It seems to have done the latter
Did you see the video? ....
I have now, yes
Return to “Simplify 3D”
