After retuning my 3DP-17 and loading it with purple filament (wife's choice), I wanted to print something that would look good in purple (meeples doesn't do it for me), so I printed a spiral vase. Cura autoscaled it down 70% to fit this printer (220x270x200 according to the included documentation). First issue I had was the stock autolevel sensor kept getting hung up on the bed heater cable connector when trying to do a corners print test from SD. Gave up on that.
Then, as it printed the vase (which looks really good), I had to cancel at 94% because the print carriage was running into the filament sensor.
I'll run the gantry back to the top with a little clearance for the sensor and take another measurement, but I think it is closer to 180mm than 200mm. And Y is 250mm because of the sensor. At least X seems right.
Print dimensions are not as advertised
Jump to
- Announcements
- ↳ News and Announcements
- 3D Printers
- ↳ General / RepRap Printers
- ↳ HICTOP RepRap Prusa I3
- ↳ Hardware Modifications
- ↳ General Questions
- ↳ Large Scale 3D Printers
- ↳ Tevo brand 3D Printers
- ↳ Resin 3D Printers
- ↳ Micro 3D Printers
- Ultimaker Printers
- ↳ Ultimaker S5
- ↳ General Discussion
- ↳ Special brand filaments
- Getting better prints!
- ↳ Help me fix this print!
- Software & Electronics
- ↳ Slicers and CAD Software
- ↳ Cura
- ↳ Simplify 3D
- ↳ Other Slicing programs
- ↳ Slic3r
- ↳ Electronics
- ↳ Firmware
- ↳ Firmware
- General
- ↳ Off Topics!
- ↳ The MarketPlace
- Modders Kiosk
