CR 10S Extruder Help!
Creality brand 3D Printers!
sudman
3D Printer(s): CR10S
Post by sudman »
Please help !
I have a 10S running MKS Robin Lite. Replaced the extruder assembly and tried to PID tune but it keeps going past the set temp by a whole lot resulting in a failed test. For example S150 goes to 230.
Replaced extruder assembly because I thought first replacement was defective but second one does the same thing
Re: CR 10S Extruder Help!
Sorry to see that somehow you got lost in the system.
Responding to your post, reply lets see if we can get this fixed.
I moved this to the CR-10 forum.
It looks like the temp sensor is out of control. Not sure where you got this firmware, but if it is from https://github.com/makerbase-mks/MKS-Robin I personally wouldn't trust it. Looks like it is run by one of the Chinese companies that make modifications to Marlin without posting their modifications.
If I were you, I'd revert back to factory firmware first to see if that resolves your issue.
I don't know what an MKS Robin Lite is?
I use the Unified Firmware made by TH3D
https://www.th3dstudio.com/knowledgebas ... e-package/
