Configurazione motore passo-passo - 17HE19-2004S
huxiangde2
3D Printer(s): Speed Boat
Post by huxiangde2 »
Ciao ragazzi, qualcuno può aiutarmi con la configurazione dei motori passo-passo? Tutto quello che capisco è che ronzano.
La scheda è una Jackpot v1.2 con stepper TMC2209 e 17HS24-2104S;
https://www.oyostepper.com/goods-53-Nem ... Wires.html
Ho giocato con i micro passi, ma questo fa sì che faccia meno o più rumore...
Ho testato con altri 2 tipi, 42HS34(L)-0954JA05-D21 e 42HS48-1204JA05-D21, da una vecchia stampante 3D, funzionano perfettamente...
scheda tecnica: https://www.oyostepper.com/images/uploa ... -2104S.pdf
Re: Configurazione motore passo-passo - 17HE19-2004S
Translated
One. Increase current: When the motor operates at low speeds, the current decreases, can lead to increased vibration and noise.
Two. Reduce load: A heavy load can increased vibration and noise
Hi guys, can anyone help me with setting up the stepper motors? All I understand is that they buzz.
The board is a Jackpot v1.2 with TMC2209 and 17HS24-2104S steppers;
I've played with micro steps, but this makes it make less or more noise...
I tested with 2 other types, 42HS34(L)-0954JA05-D21 and 42HS48-1204JA05-D21, from an old 3D printer, they work perfectly...
technical data sheet: https://www.oyostepper.com/images/uploa ... -2104S.pdf
I have no idea what that board is. Or how it relates to this topic
