VScode anyone want to help me figure this out
I have tried to compile firmware using vscode and I can never get it to compile. I am at a lost . Is there anyone willing to help me understand what I am doing wrong
Re: VScode anyone want to help me figure this out
Well I can try to help or at least give you information that can help you.
I appreciate that . I have been trying to compile one for 2 months for my Chiron using a btt skr 1.4 t and I can not get it to compile I am at my Witt’s end
Post the code alone with any information you think I will need in order to successfully complete the task. I will see if it compiles.
Debug the code if not Then we can decide if you want the repaired code and successfully complied bin file.
Or if you would like to try to finish the task alone using steps to learn what went wrong.
Either way you will end up in same place with compiled source code.
Start with any modifications from the original 3D Printer
It would also be nice if you have an older working source code to use as an example.
Will get it uploaded soon
