Help with failed print
retiredgoat
3D Printer(s): Elegoo Saturn Ultra, Bamboo A1, Tenlog TL-D3 Pro,
Post by retiredgoat »
I have tried several times and the print splits toward the build plate. The tube is hollow, so I don't think it's a suction issue. Any idea what might be causing this, appreciate the help.
Re: Help with failed print
Could use more information about the print.
What filament
What Nozzle Temp
What bed Temp
Is the model being printed in a temperature controller area or could a cool breeze cause the split.
Please give us more information to work with.
retiredgoat
I'm using Sunlu High Toughness Resin, the printer has a heater and the resin is a constant 76F, calibration indicated a 2.2 second layer exposure was best. In my garage with the door closed and lid down so no breezes.
Could you show a side view, as if you are looking directly at the printer.
I had a problem like this a while ago, I think it was a support problem, they were too thin.
retiredgoat
Thanks for the reply, here are some more views
retiredgoat
Let me try this again, keep getting a HTML error.
IMG_3.pdf
(24.74 MiB) Downloaded 387 times
I think the part might be flexing while printing.
Try thicker supports.
shadowpunk
3D Printer(s): Mars 3
Post by shadowpunk »
in my experience cracking can sometimes be from Lack of Support
Return to “Resin 3D Printers”
