Marlin manual Bed leveling Leveling increment tweaking
pochrist
3D Printer(s): Maker Farm Pegasus 8 & 12
Post by pochrist »
Using a Makerfarm Pegasus 8 which in turn is Using Marlin Firmware 1.x, trying to improve my accuracy and was wondering if there is a way to tweak my setting for the manual leveling process.
When performing a manual bed level, when i turn the knob the x carriage moves up or down at .5mm increments (I think) is there anyway i can lower the number to .25mm or .1mm.
Perhaps I'm being anal, but I like to be as close to possible when running the process.
Thanks
Re: Marlin manual Bed leveling Leveling increment tweaking
Are you looking for
#define MBL_Z_STEP 0.025 // Step size while manually probing Z axis.
pochrist
Post by pochrist »
Perhaps, is this line already in the Marlin Config.h or am I adding it? Conversely is there a way to do it via Pronterface and gcode commands?
I found it in all versions of marlin 1.1.x that I have programmed for My 3D Printers.
I do not know of a way maybe, someone else will know.
Mr SNG
Post by Mr SNG »
If its of any use I redesigned an Auto Bed Leveling Sensor Mount. Unlike the 3 part assembly thats on Thingiverse, my one is only a two part and fits the linear bearing housing perfectly.
If I get the time I guess I should upload the files onto Thingiverse as its easy to fit and adjust.
You can also post a picture here.
jean121
Post by jean121 »
The print beds on 3D printers aren’t always perfectly flat. Sometimes you can get lucky and get a pefectly flat surface to print on, but considering the materials the bed is made out of and the constantJT whatsapp heat cycling, it’s more likely that you’ll have to deal with at least some warping.
Mesh Bed Leveling
There are few options for compensating for a warped bed, but I chose to use Mesh Bed Leveling because it didn’t require any extra hardware or tools.
This does require building a custom configuration for Marlin.
At a minimum, enable mesh bed leveling in Configuration.h:
Stephen21
Post by Stephen21 »
Mr SNG wrote: June 4th, 2020, 7:06 am If its of any use I redesigned an Auto Bed Leveling Sensor Mount. Unlike the 3 part assembly thats on Thingiverse, my one is only a two part and fits the linear bearing housing perfectly.
WhatsApp Aero APK
Can we get the link please?
SNo4 Proximity Sensor Mount here
I have designed a mount for Omron TL-W3MC2 attached, was looking here could not find my post so re-posted link
New Hictop Sliding connector.stl
(31.43 KiB) Downloaded 1095 times
New Hictop Sensor Mount v2.stl
(35.92 KiB) Downloaded 1074 times
queenmari
3D Printer(s): s printer
Post by queenmari »
Stephen21 wrote: July 14th, 2022, 10:02 am
Specifically, you have to make sure the frame is rigid, especially the portion that supports the Y axis guide rails, and use a flat plate.
thomascook
3D Printer(s): Ultimaker
Post by thomascook »
I will suggest you adjust the probe points, select the bed leveling method, and give access to the configuration. I think this will work enough.
Youtube Vanced APK
Rohan77
3D Printer(s): FDM 3D
Post by Rohan77 »
When manually leveling the bed in Marlin, fine-tuning the leveling increment can make a significant difference. Start by adjusting the screws to get the bed as flat as possible. Then, use the leveling increment feature to make small, precise adjustments. This allows you to dial in the perfect level without overcompensating. Remember to check all corners and the center, ensuring even spacing between the nozzle and the bed. youtube vanced
Zarina99
3D Printer(s): yes
Post by Zarina99 »
The manual bed leveling feature in Marlin firmware enables the surface of the print bed to be adjusted. By modifying the step size for every manual leveling adjustment, the "Leveling Increment" comment allows for more accurate height adjustments to be made throughout the bed leveling procedure for the best print quality.
vanced youtube
