Model will slice but won't print
tfalcon
3D Printer(s): Anycubic Predator
Post by tfalcon »
Hello,
I sliced my model in Cura, seemed to slice okay, but when printed it only printed for about four seconds and then said print complete. Not sure if I am missing a setting in cura?
Re: Model will slice but won't print
It would be helpful to post your Cura Settings
Or you could examine my Cura Settings posted here
In some cases we need the Model to be able to do testing, to see what special setting may be required.
OR
Maybe the model has flaws an is in need of repair.
tfalcon
Post by tfalcon »
Thank you for your response. The problem seems to be the model, I put it into mesh mixer and tried to go through their repair process and it deleted half the model. Do you mind taking a look at the model? Specifically the one with "bottom" in the name.
https://drive.google.com/drive/folders/ ... sp=sharing
