I have a spool of
FlexiFill from FormFutura. I believe it is exactly the same as the Ultimaker FlexPLA (I have both, they feel the same, and they had in the past exactly the same spools).
As reibuehl says, once printed it is not that flexible. If you print a flat part it will fex well, but you print a more structured part it it will become stronger. We used it in the past to make
molds, but it was actually too rigid for that (It was before I learned about NinjaFlex!)
FormFutura is selling samples if you want to try...
