I've never used this...would this be the ideal way to save settings for different filaments?
I haven't tried it but was wondering if that's what this is designed for....and how well does it work?
Profiles?
Re: Profiles?
In 2.2 the profile stuff will be reworked.
In it's current state the profiles are a bit weird. Especially for materials.
- drayson
Re: Profiles?
I made an excel sheet which generates the material profile files out of the data you put into the table e.g. temperature of head and bed, some settings related to the use of special filament etc.
Should be attached so feel free to use it...
- Attachments
_Material Data.xlsm
- generate material cfg files out of an excel spreadsheet
- (26.83 KiB) Downloaded 494 times
