Have been looking at many designs for this Harbor_Freight_Palm_Light this was one of the best Harbor Freight 27 LED Worklight 18650 Lithium Ion Conversion
This one is for Harbor Freight LED COB 18650 conversion 2020 model by adawg08 on Thingiverse
Though have found one that better suits my needs Dual Harbor Freight Work/Filming Light (18650 powered)
I would like to see more than one 18650 battery, Have decided I want it to have two 18650 battries in parallel.
Now to figure out a way to utilize the original power switch to allow for Dim and bright light levels.
Have already removed the unnecessary Go Pro mount. Now need to figure out how to add a battery mount for two batteries.
Cannot insert the Dual_Harbor_Freight_18650_Light v1.3mf file here
Oh!
In a different post stated that I learned how to make a Hictop controller Case by learning every step as I needed them, still slow on modify already existing models using Fusion 360.
Though I will figure it out, this is one of the reasons for deciding on a 3D Printer hobby, there is always something to learn.
This time need to learn how to extend the battery mount or delete it and make a completely new dual battery mount.
Or
Build the battery mounted center on bottom plate much easier an at the same time add the original clip magnet notches for bottom plate believe dual magnets will work.
Dual_Harbor_Freight_Catfishing_Light
Re: Dual_Harbor_Freight_Catfishing_Light
Decided to remix the Dual Harbor Freight Catfishing Light Removed Go Pro mount, 18650 battery mount and changed to USB C charger port.
Today my merchandise to Start the remix Dual Harbor Freight Catfishing Light was given a delivery date October 7.
I will now test print my remix to see how the parts i do have fit into place, an what may need to be fixed.
The parts I have ordered are AWithZ spot welder, 18650 battery charger 3A, Premium nickle strips and Type-C Female 2P pig Tail.
The pig tail has no dimension specs, found similar item with specs using those specs hoping they were the same.
As the pig tails looked exactly the same.
