Hello all
I've tried a couple of different build surfaces and I get issues with each. My aluminium heated bed is warped, and from what I can gather this is quite common with aluminium plates. I'm interested in hearing the advice of others on what they have found to work well on their printers; I'll detail my experiences below.
Heated aluminium build plate lined with masking tape:
Excellent adhesion, but some issues with under-extrusion: the warp in the bed brings the nozzle too close to the bed and the nozzle gets blocked.
Heated aluminium build plate with no liner:
Pretty much unusable. When I properly level the bed, the nozzle will hit the build plate when moving across the X-axis (the plate appears to be warped upwards along the centre of the Y-axis). Lots of extrusion problems due to the nozzle being too close to the warped part of the bed.
Heated aluminium plate with borosilicate glass build surface:
Very flat surface, so I get perfect bed leveling. But... the glass is 200x300mm and my alu plate is 220x275mm, and all of my prints lift. From what I gather this is due to the temperature differential: glass absorbs heat very well, so the lower layers are warmer and more pliable than the upper layers: et voila, printed items lift. I get the best results with this method so far (see these examples - sorry for the facebook links! https://i.imgur.com/Kqg0Rgb.jpg https://scontent-lhr3-1.xx.fbcdn.net/v/ ... e=58B5CF99 https://scontent-lhr3-1.xx.fbcdn.net/v/ ... e=58F481E8 https://scontent-lhr3-1.xx.fbcdn.net/v/ ... e=58B83843)
Un-heated aluminium build plate lined with masking tape:
Not tried.
Un-heated aluminium plate with borosilicate glass build surface:
Not tried.
Un-heated aluminium plate with borosilicate glass build surface lined with glue stick (or some other material):
Not tried.
I've also tried an inductive Z-probe so that I can use automatic mesh bed leveling. That's currently on hold because the sensor I bought appears to be knackered and the seller is being really fussy about refunds/returns (the sensor accepts 6v-12v; the output should be 0v when not triggered and the same as the supply voltage when triggered - my sensor reads 6v out (on a 12v supply) when not triggered and 4.7v when triggered). I can trigger the Z-min input when I hook it up to my bench power supply and feed in 5v, but the sensor itself appears to be knackered.
Based on everything I've learned so far, my best bet seems to be an inductive sensor and mesh bed leveling. That should allow me to use the bare aluminium heated bed and have the software compensate for the warp in the bed. While I shout at some useless seller about a replacement sensor (I'm not buying a new one, I begrudge paying out of my own pocket for a faulty item) there are still quite a few things I'd like to print. I'd be keen to hear any advice people might have on build surfaces.
FYI: I print PLA at 205°C with the bed set to 50°C (60°C first layer); I usually use a layer height of 0.2mm. I can post my Slic3r settings if needed.
Build surface advice
- Meduza
Re: Build surface advice
Borosilicate glass with glue stick, it is what we use at our Ultimakers and it works great!
Agree with Meduza, Borosilicate glass plate,and depending on the material to be printed then either gluestick or hairspray or for a ABS perhaps ABS gunk or PrintaFix
Yes glass is the way to go
- Chaco
I have always used Glass and glue stick. Love the fact that never had adhesion problems, and loveeeeeeee the smoothness glass leaves on that first layer.
A little razor scrape, some 91% alcohol or water on a paper towel, and BAM, clean as new. CAN NOT go wrong with this. As i have done it few hundred times and works every time.
BUT...........
Just last night i went to Microcenter to get some more filament, and a few other things. I noticed they had BuilTAK there, so i got it to test it out.
I never used my inductive sensor with ABL because i never got good adhesion on while using tape over the bed.
So i got home, removed my glass, installed the BuilTAK, calibrated my inductive sensor, and test it out.
WOW, im very impressed at how well that works.
No glue + heat = Great adhesion
No glue, no heat = Great adhesion
So i am literally blown away at how good it is. The first layer looks good! Cant "Squeeze" it as much as i did with glass, but still looks good. )(Instructions to warn too much squeeze will be hard to remove without damaging the TAK or the part.)
Only time will tell how well it holds up with use. For $12.99 i think it was worth it.
BUT...........
danilius
I use plain float glass, the stuff you put in windows. Works just as well as borosilicate and is way cheaper. I use UHU glue stick and that works with PLA, ABS, Taulman bridge and PETG.
Sorry, I meant to come back and update this sooner...
Thanks for all the replies. I've stuck with borosilicate glass for now. I'm going to try mesh bed leveling though, so I will take the glass off while I try that.
- antiklesys
I'm using PEI on heated aluminum bed.
IT IS AWESOME!
You can get a sheet of it from either Amazon or the prusa website and you can fix it to the bed with a 3m double sided tape sheet.
IT IS AWESOME!
