I'm curious if this ability is within Cura?
I know we can use Materials.Txt on the Ultimaker 2, which requires a reload each power on.
But is there a simple way to go into Cura and, for sake of example, have the settings load for using ColorFabb nGen and key those settings in? Or any other filament that requires some changes from what's pre-loaded?
How to save various filament settings?
Re: How to save various filament settings?
I have all of my filaments entered into Cura. A few of them have my own print calibration settings as well (I have been lazy and haven't run a calibration on each spool).
In Cura 2.6, open the Preferences interface and select the Materials tab. From there, you can either create new or duplicate existing entries with various parameters like diameter, cost, density, and even print settings like temp, bed temp, retraction speed, etc.
- drayson
I made an excel sheet for all my materials where I can export the corresponding material setting files and just copy them into the user app settings folder (or however it is named...)
This is great, I didn't know you could do this now!GrueMaster wrote: ↑June 27th, 2017, 2:13 am I have all of my filaments entered into Cura. A few of them have my own print calibration settings as well (I have been lazy and haven't run a calibration on each spool).
